Differential Gasket Type 8 3/4 A Body
mario03srt
Hillsboro Oh 45133
All,
I'm putting in my new 3.55 Sure Grip in my 8 3/4 and have ran into an issue. I had a Fel-Pro diff gasket given to me with the car. It does not fit due to bolt spacing. The 2 bolts @ 11 and 1 o'clock are unequally spaced on the diff and housing. All others I searched for on line have an equally spaced bolt pattern.
Can someone please point out my error and please share the correct p/n(s)?
Thanks,
Marion
i always just use silicone.sorry no part #,all 8 3/4 should be the same
I have 4 gaskets same off set holes checked 2 rear housings same off set.You can use aform a gasket . Its the copper washers for the studs that matter most :oops:
Dr Diff comes through again!
