daves 72 dart
ok i need a new dip stick tube.what kind would you guys run and where do i get them?thanks
oops
I got a real slick looking Billet dipstick and chrome tube off of E-bay for $13 shipped a couple months back.
stacked a bunch of sockets on it and tapped it in. p.
Did it fit into your block? I have bought a couple of those chrome ones (probably made in China) and had to grind them down to fit into the block. Once I did that, they were weak, and easily broken.
I finally ordered a stock one through a Dodge dealer, and wow, they were proud of that little thing. I am going to have to do it again for this motor.
Fishy if the engine is not painted heat the block with a heat gun or torch around where the dip stick goes in so the metal expands. File the end of dip stick tube where if goes into the block to create a slight taper. Put dip stick tube in freezer overnight. Then use sockets stacked up to tap it in. The first socket that meets the lip must fit very snugly.
Oh, and I used the plain steel dip stick tube from Mancini.
The block is painted but I'll keep the other parts in mind. I haven't tried it yet so I don't know if it's even a problem yet. Thanks for the info.
