1. khaley71
    khaley71 FABO Gold Member FABO Gold Member
    607
    48
    Mar 17, 2010
    Maryland
    Local Time:
    4:51 AM
    I have a 71 Dart Swinger that I converted from drum to disc. I pulled the manual disc set up from a 74 Dart Sport. The conversation is done and works fine but. I have a rattle from the passenger side disc brake pad. It started out as an occasional rattle but as the pad wears it’s getting worse. I’ve taken it apart and checked for wear and loose parts. Everything seems tight and as it should. Is there an anti rattle clip or something that should be there? Does anyone have a picture from a 74 FSM they would be willing to post? I don’t know if I am missing something.
  2. Dana67Dart
    Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
    3,273
    1839
    Jul 16, 2017
    Northern Colorado
    Local Time:
    2:51 AM
    FSM available at mymopar.com free download
    • Like Like x 1
    • hemi71x
      hemi71x FABO Gold Member FABO Gold Member
      5,163
      1715
      Dec 22, 2009
      Rancho Cordova, CA
      Local Time:
      1:51 AM
      Did you bend down the "tabs" on the metal portion of the pad, so it fights nice and tight onto the caliper body?
      • Agree Agree x 4
      • Like Like x 1
      • khaley71
        607
        48
        Mar 17, 2010
        Maryland
        Local Time:
        4:51 AM
        I did not but, I’ll take a look and see if they need to be bent down. Thanks for your suggestion it’s definitely appreciated.
      • khaley71
        607
        48
        Mar 17, 2010
        Maryland
        Local Time:
        4:51 AM
        Thank you for the information, that’s great to know. I really appreciate it.
      • RustyRatRod
        RustyRatRod Weenie idiot loser. FABO Gold Member
        57,895
        27898
        Jun 7, 2010
        Georgia
        Local Time:
        4:51 AM
        This ^^^^^^
        The outboard pads have metal tabs that fold over the caliper. You need to take a pry bar and gently pry up on the bottom of the pad and smack the tabs down with a hammer. That tightens them up and will stop the rattle.
        • Like Like x 2
        • Agree Agree x 2
        • khaley71
          607
          48
          Mar 17, 2010
          Maryland
          Local Time:
          4:51 AM
          Going to check it and see if that’s what it is. Will be great if it’s something that simple. Sometimes you miss the obvious stuff.
        • RustyRatRod
          57,895
          27898
          Jun 7, 2010
          Georgia
          Local Time:
          4:51 AM
          I feel sure that's it. That explains why it's getting worse as time goes on. As the pads wear, the gap gets bigger. Good luck!
          • Like Like x 1
          • Kendog 170
            Kendog 170 Well-Known Member
            496
            249
            Mar 10, 2016
            Tewksbury Ma.
            Local Time:
            4:51 AM
            MN8007.jpg The rectangular anti rattlers in pic can get old. Mine rattled until I replaced them. You can probably bend them or replace them. Rusty's suggestion also.
            • Like Like x 1
            • Joey4speed
              Joey4speed FABO Gold Member FABO Gold Member
              443
              242
              Jul 17, 2018
              Jersey
              Local Time:
              4:51 AM
              Weren't the rubber bands supposed to help with the rattle?
              • Like Like x 1
              • 66Dvert
                66Dvert Working on my custom car parts again! FABO Gold Member
                2,342
                593
                Nov 2, 2008
                Webster , florida
                Local Time:
                4:51 AM
                In that pic are some rubber o-rings. just exactly where and how do they fit/go? anyone got a picture of them where they go? I'm so old I trained on Drum brakes as a kid and then went to work at a dealership before disc brakes came out,then moved to bodywork when they did come out. I've done my brake pads for years without them and never used them and all without a rattle, so are they needed? I tried FSM'ing them but no clear picture.
              • Kendog 170
                496
                249
                Mar 10, 2016
                Tewksbury Ma.
                Local Time:
                4:51 AM
                I've never used the o-ring. New to me .Noticed them for the first time when I got pic off Rock A. for reference. Maybe they hold the pad from falling while installing ?
                • Like Like x 2
                • abodyjoe
                  abodyjoe Well-Known Member
                  20,217
                  5050
                  May 22, 2004
                  Berlin,N.J. 08009
                  Local Time:
                  4:51 AM
                  thats what i was thinking.
                • Tooljunkie
                  Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
                  12,409
                  11047
                  Jul 22, 2017
                  Manitoba
                  Local Time:
                  3:51 AM
                  I used to wedge a chisel in instead of a pry bar,and hammer the tabs. Seemed to work well for me.
                • Joey4speed
                  443
                  242
                  Jul 17, 2018
                  Jersey
                  Local Time:
                  4:51 AM
                  The rubber O ring wraps around the caliper wings before installing the pads. I guess in theory the rubber should stop the pad freeplay.?
                  • Like Like x 3
                  • khaley71
                    607
                    48
                    Mar 17, 2010
                    Maryland
                    Local Time:
                    4:51 AM
                    Just wanted to give an update and say thanks. I finally found a little time to work on my Swinger. You guys were right on. A few taps with a hammer and punch on the tabs of the brake pad and my rattle is gone. I greatly appreciate the help from all of you.
                    • Like Like x 3
                    • RustyRatRod
                      57,895
                      27898
                      Jun 7, 2010
                      Georgia
                      Local Time:
                      4:51 AM
                      Well good. Glad it was that simple......there wasn't anything "wrong" and that's always a good thing.
