disc brake rod bushing
khaley71
Maryland
Hey gang im looking for the bushing that goes on the end of the brake rod into the back of the master cylinder. I beleave it holds the brake rod in place. I also need the small rubber bellow that slides over the brake rod. I think it mounts between the master cylinder and the firewall. Thanks alot everyone
The bushing is in any rebuilt M/C box along with the bleeder kit. Im sure you can get them seperate. My new one looked like a little black rubber collar. Dont know about the bellow. Dont really need it?
I assume you have manual brakes. A power brake MC rod is different and doesn't require a collar. I would try finding an O-ring that fits. I suspect the rubber collar is just to avoid rattling. I don't think there is room for the rod to pop out of the piston. The designers would be stupid to rely on the rubber.
Hey guys thanks for the info. I am just going to skip the bellow maybe find one at a later date doesnt seem to important. For the rubber collar I cut down one of those rubber vacum port block off caps. Im swapping from sbp 9inch drum to bbp manual disk. Thanks again guys.
