The spindles and rotors will work. The caliper brackets may be the pin type, but they will also work without any problems. The only issue may be that calipers themselves. I know for sure that there are '73/74 calipers out there that won't work, I'm not 100% sure on the crossover because at some point that body went back to the slider style calipers. Anyway, if those brakes are the pin type you just have to make sure your calipers don't look like the ones on the left, they have clearance issues on A-bodies. The E-body style works fine.
