Disk Brake Question
LabRat802
Vermont
Good afternoon everyone, I was curious if anyone had experience with this kit-
1966-74 Dodge Dart Mopar A-Body Front Disc Brake Conversion Kit for 5x4.5 Bolt Pattern & Manual Brakes
Seems alright, but didn't know if they were all 1 off parts that I wouldn't be able to get my hands on at my local parts store or if they were OEA Parts. Just don't want to eventually have a stuck/leaking caliper and have to only be able to deal with Pirate Jack. This kit would be going on to a 1970 dart swinger.
PS- I'm new to all of this, so if i left anything out let me know. Thank you!
Only way to find out for sure is to contact Pirate Jack.
Looks to be OE replacement parts which means that calipers, rotors, berings etc... will be over the counter parts.
Get them at Napa etc...
That's just a 73-76 A body disc brake set up. Nothing special there. Every wear part should be available at your local parts store. Now the question is what are you going to do for the rear axle to make it the same bolt pattern?
A body 8-3/4", big bolt pattern axles, new 3.73 gears with a Sure Grip unit.
