today, i fired up my 360 magnum, and some of you guys know that i had a miss fireing issue that i thought i had tracked down. But i guess i was wrong about finding the problem because it the miss firing while at an idle was back today.
It didnt last for long.. One the engine was warmed up it stopped. But i am begining to wonder if this issue is inside my distributer? i'm thinking there is a good chance the air gap on the reluctor and pick up coil being off could cause a miss fire at idle. My distributer is brand new with less then 1000 miles on it, i purchased it from Don at fbo systems, and he curved and phased it with his distributer machine. He suggested i set the initil timing at 16 degrees wich would land the total at 34 degrees because there is 18 degrees in the distributer. And he suggested i hook my vaccum advance up to manifold vaccum.
So i do as he instructed when i first got the distributer and it never ran right that way, thudding out the exhaust while at an idle. It runs fine thru out the entire rpm range doesnt miss a beat, but at an idle i'll be damed if i can find whats causing this stuid little miss fire. It does it more noticeably when the vaccum advance is hooked to manifold vaccum. Right now i have my vaccum advance on ported vaccum And i have my initial set at 14 degrees and total timing at 32 degrees with vaccum advance on ported.
I have crane cams lx91 ignition coil a wells ecu box a wells 2 prong ballast resistor at 1.0 ohms. My wells ignition box is grounded good, i have aa 10 gauage ground wire running from the ignition module mounting bolt to the engine block. All of my ignition wiring is brand new including my ecu ignition module connector and wires pick up coil wires coil wires its all brand new and done up real nicely. My spark plugs are brand new ngk v-powers zfr5f11's i also have 8 brand new autolite 3923 plugs all of them gapped at .035. My plug wires are new borg warner select 7mm's they have about 500 ohms of resistance per foot.
Everything on this is brand new ignition wise and is wired up correctly and i still have this miss fire out the exhaust, i am so frustrated with it because it shouldnt be doing this. I tried the autolite 3923s to see if that would help, and it did help it run a little better, but after about 3 or 4 days of running the 3923 plugs this miss fire is back? and it came back today because i tried turning up my initial timing from 14 degrees to 16 degrees and thats when i noticed the miss fire was back, i put the ngk v-power plugs back in it and set my initial timing back to 14 degrees and it seemed to go away once it warmerd up?
When i had the distributer cap off i pushed down on the pick up assembly plate and that did something to it because once i put the cap back on and fired it up it was running crummy, thudding out the exhaust.
I thought i read online somewhere that don sets the air gap differently on his distributers, does anyone know this for sure?
