Does AC/heater unit come out as one?68 Dart
BigAl
Member
Bloomington Indiana
Hi, I read the other posts but wonder if I need to remove anything other than the spliced place on the vacuum lines just down from the control on the dash? Also does the blower motor come with it thru the firewall? Mine seems stuck trying to remove from the engine compartment. So when it's all loose will it have room for the entire A/C (factory under dash output) to come out?
everything pulls inward to the passenger compartment. Make sure you have all the connections and nuts off the firewall that hold the box and A/C-heater hoses....
There's a long J bolt with a nut inside the vent box too. A service manual would be a great help.
Yay... I'm trying to remove the blower motor on my 64.... This shall be fun. I don't suppose anyone has a diagram of the blower motor R&R by chance?
