gzig5
I'm at the point where I'm going to need to take the doors off and on occasionally and working by myself, it is a PITA. They really want to tip over when just balanced on top of the jack. I'm looking for ideas, pictures, or vivid descriptions of an assembly I can use with my floor or transmission jack that will reliably hold the door in position while I zip the hinge bolts in. Some level of fine adjustment might be desired. I've used a temporary bracket made of wood but it was sketchy and I'd prefer to weld something up and bolt to the jack table. I'm in the rough bodywork stage, fixing rust on the A-pillars, cowl, and fitting full quarters and roof skin. This is on an E-body but I imagine the A, B, and C bodies suffer as well.
