[Found!] door locks w/ key and letters 65 dart
Cars and Mopar Parts Wanted
Thread Status:
  1. hosehead
    hosehead Well-Known Member
    1,191
    982
    Dec 4, 2008
    Grand Lake o the Cherokees
    Local Time:
    6:15 PM
    Contact Seller
    Looking for the "R" and the "T" for a 65 dart. The ones on the quarter panel. Also a pair of door locks w/ a key so I can lock this thing.....
    PM me if you have anything. Thanks
  2. THEMESSMAN
    THEMESSMAN Active Member
    36
    6
    Mar 9, 2015
    Torrance California
    Local Time:
    6:15 PM
    If they car still has the door locks just send it to a lock smith and have them make a new key that’s what I did for the locks. It’s going to be the same as your ignition key if it wasn’t switched.
  3. hosehead
    1,191
    982
    Dec 4, 2008
    Local Time:
    6:15 PM
    ignition key doesn't work
  4. THEMESSMAN
    36
    6
    Mar 9, 2015
    Torrance California
    Local Time:
    6:15 PM
    Then it must have been replaced. You can also have the door locks rekeyed to your ignition
  5. pishta
    pishta I know I'm right....
    22,914
    12361
    Oct 13, 2004
    Tustin, CA
    Local Time:
    6:15 PM
    I thought the door key was round and the ignition was pentagram? 2 different ones...original 1965
  6. THEMESSMAN
    36
    6
    Mar 9, 2015
    Torrance California
    Local Time:
    6:15 PM
    Trunk is one key the round one and door and ignition is the other.
    • Thanks! Thanks! x 1
    • GTGrinly
      GTGrinly Well-Known Member
      1,488
      33
      Jun 2, 2006
      Central PA
      Local Time:
      8:15 PM
      Ive got some letters, hit me up with a message. I'll be home by Wednesday..
    • cudamark
      cudamark FABO Gold Member FABO Gold Member
      9,778
      1902
      Mar 14, 2009
      San Diego
      Local Time:
      6:15 PM
      Your door key looks to be an original, but, not the trunk/glove box key. They should have the same type eye sticking out from them as the ignition key. If the OP's door cylinders are broken, I should be able to put together a genuine '65 matching pair with an original style key. If they just need to be re-keyed, I can do that too, but, it would probably be cheaper to have a local locksmith do it, and as mentioned, have them pinned to match your ignition key.
    • pishta
      22,914
      12361
      Oct 13, 2004
      Tustin, CA
      Local Time:
      6:15 PM
      cool, Those were handed to me when I bought it out of a warehouse after 25 years of storage.
    • hosehead
      1,191
      982
      Dec 4, 2008
      Local Time:
      6:15 PM
      Thanks Mark, I just bought the car and it came with one door/ignition key. I'll have to copy that and then try and get the locks I have rekeyed.
      The problem for me is I live in rural Oklahoma with not a lot of anything around. I'll research a locksmith I guess but I wouldn't be surprised if I had to drive out of town a fair bit to find someone to do that.
      Send me a pm for what you'd need to purchase a set of locks with a key. Thanks!
    Thread Status:
