Moparnutt340
I just picked up a 2001 Dakota for a beater/work truck
It had a bad leak in the brake line so the fluid was empty. I dumped in a full bottle of Dot3 brake fluid, which was a waste because I still had no brakes anyways. Drove it home an hour away with no brakes. Thankfully its a 5 speed so downshifting to stop worked out for me.
So today I changed the brake line. I went to put fluid in it and read the cap which says Dot4 fluid only. It still has some dot3 fluid in it from the drive home.
Can the 3 and 4 be mixed or should I drain it ?
Will it do any harm if I run dot3 instead of 4?
