Somewhat odd. LA 360 with PS and AC. I noticed an engine noise (not squeal of screech) at rpms over 2500 and wound up replacing my 10 year old v-belts. Problem solved. Within approximately 400 miles The symptoms returned. All is fine at lower rpms however I noticed that the outer belt on my double pulley Alt/AC/crank has a lot of play in it. You can see it kind of "flapping". Unfortunately I did not take notice on my old belts if I had the same issue but I assume it was. I still have the old belts. Both new belts look to be seated in the pulleys the same amount and I know my pulley alignment is good because nothing has been changed in many years. All brackets and mounts are solid. I was thinking of taking one of my old "stretched" belts and swapping with the new inner belt. This may give me the ability to get them balanced and see what happens. Another thought is to run a single belt (I believe I read that here) as my A.C. is not currently charged however it is on my to do list. Any thoughts or similar experience?
