Dream 67 440 gt dart
Finished the door panels today and they look great as far as i am concerned
took the emblem off of the old panels
Another great rebuild thread! Good job so far and good luck with the motor!
Welded plates on for the subframe connectors
Pulled motor
Pulled trans
Started tear down on motor for rebuild
did a bit of wire wheeling today
dont have pictures of it all sorry
Engine tore down and off to the machine shop!!!
Already has windage tray
6pack rods (I think)
lightend crank
906 heads
eddy intake
I'm so excited dreamed of the day I send an engine out to be machined
just tells me I'm getting closer to hearing it.
I CANT WAIT
getting magna fluxed. Hot tanked and honed. Or both honing and boring
Hey, good job you are doing! You're working faster than me! Keep at it!
Motor needs to be sleeved so i will not be using it
i have a lead on a 400 that i can put the 440 internals in and build a stroker 451 thats probably what i will be doing now.... more money yay
got one subframe connector welded in today will have pictures tomorrow
wow...... your going to town on this ride. Its going to be great... as for the stroker.... way to go ! All I can say is... HANG On !
nice job !
-RPM
Went to pick up the tranny. And it was missing everything he said it had. Drove there for nothing. Sick of liars
thanks for the positive feedback
made a plate, drilled and welded 65 spot wleds. will use seam sealer in the next few days still have a bit of pounding and grinding to do
tank will hang down 7 or 8 inches and it will stick up in the trunk a bit
Any particular reason the fuel fittings are facing towards the side of the car?
