[Found!] Drive shaft for 70 Duster 340 with 904 trans.
I may have one that size. I'll check and let you know later tonight
I have a good used 1 pulled from a 1970 duster with 904 trans and 8 3/4 rear axle. Went with 727 and custom shaft. It'll be a few days before I can measure.
how did you measure so it can be measured the same - I have a Denny's STR 3 that I would sell. message if interested
I might have one, came from a 74 Dart Sport that I put a 8 3/4 rear in. I would have to measure, and I think that it is a small u joint
the measurement came from a Mopar site. I did an actual measurement and it was pretty close
I've got a nice 51.25" u-joints center-to-center driveshaft with 904 yoke. Good u-joints.
I can't find a consistent spec for a 108" A-body w/904 and 8 3/4" rear driveshaft but a 904 is 4" shorter than a 727 and an 8 3/4" extends .66" more towards the trans than an 8 1/4" from the axle centerline. My 108" wheelbase, 904 & 8 3/4" Dart Sport isn't at home so I can't measure the driveshaft in it but I believe it was closer 49"-50".
How much to shorten & balance a drivehshaft where your at?
