[SOLD] dual point distributor
4spdragtop
Ontario Parts Unknown
Hi all here is a dual point distributor. Needs a good cleanup. Shaft turns freely with no slop. Tag reads 3438225.
$30 plus the ride
Thanks
Steve
My book says that number is for a 318 2bbl. I'd say the tag is off another distributor.
Whats it for pray tell?
Small Block
Yes I pulled it from sb. 273 car but not sure what the engine currently was other than sb
I pulled tag and no numbers underneath. Weird why someone would change the tag to a 2bbl. Body is magnetic so cast body then right? When did they change to aluminum body? Doesnt appear to be messed with other than tag possibly being switched??
I would peel it apart and go through it if you are going to run it.
Thanks all
Steve
The rotor looks like a Ford rotor. I wonder if it's a Autolite. The Prestolites are cast iron and smooth. It looks like a aluminum single point housing with the waffle casting.
You know what? That's the craziest distributor I have ever seen. I just gotta have it. PM sent.
Here's a '71 for comparison..............
Dual point Mallery dist. were part of the Formula S package in 1966. It may have also been used other years. Not use if the shown is the Mallery.
Mike
I noticed today when I spin it that it sometimes "catches". I.don't think its a huge issues but I would recommend going thru it.
Thanks
Steve
Mike
Just to clarify, the HP 273 dual points were cast iron housing units made by Prestolite. The correct numbers for 1966 were Model # IBB-4013a Part #2642242 and replacement
#IBS-4013AB and #2642461 for non CAP (Clean Air Package {California Emissions})
The CAP part numbers were #IBB-4013B #2642358 and replacement numbers #IBBS-4013BB and #2642405. tmm
