waggl1
Member
So ive found a pair of dual spark plug heads for a 440BB. What kind of electrical system will I need to run this?
http://www.racingjunk.com/Heads/181859887/hemi-aluminum-heads.html found them off this site.
They are Dual Plugs, for a 426 Hemi.oh my apologies...kinda new to the mopar world excuse my lack of education. I just saw the two inserts on the top of the head so I assumed they were dual spark plug heads.
Con...It will cost twice as much for plugs and wires...LOL
I don't remember if they were EVER exactly successful. I remember some of the pro stock guys went back and forth with 'em in the 70's, used to see some run with the dual plug heads but the second plug "plugged."
They do this with aircraft, some older gasoline fire trucks, etc, but I always understood it was for reliability
:dontknow: I think the dual plugs had some issues with dual 'flame propagation' causing problems. IDK, something about the flame fronts crashing into eachother .
Thank you for the input on this situation. I guess its single plugged heads for me haha. I just thought it would help being an advantage in running a turbo but now im thinking itll just be a bigger hastle.
no offense but if you cant tell the difference between hemi and wedge heads your not ready to jump into the world of boost... you need some time behind the wheel of a stock slant six car to learn maintenance and simple upgrades and the effects (good and bad). after that maybe look into a big block or small block, or build a slant for boost without the boost for awhile.
The average carb street engine there isn't really any advantage to dual plugs. Ford used it for years on the 2.3L ranger motor and chrysler is using it on 3rd gen hemis and later 4.7's, but for all normal purposes 1 plug per cylinder will get the job done just fine.
