73 Plymouth Duster
So 73 duster with a 318, starting problem has re-emerged. I have replaced
-ECU
-ballast
-alt reg
-coil
-mag. pickup in distributer
-ign switch
Car starts periodically. I swore it must be a loose wire in the harness but after looking for 2 hours and ohm checking everything it doesn't appear so. HOWEVER when you unplug and plug in the ecu box there is a clicking noise (like an electrical short) coming from the distributor.
We tested there IS voltage at the ballast in start and run, like 10volts but only 5volts and 8volts at the coil (so it is loosing half somewhere) (like a short in the dist?) anyways when we unplug and re-jump the plug to the ecu except the top plug the coil WILL get full volts.
I think there is something wrong in the distributor, the magnetic pickup is kinda loose in the distributer and is only tied down with 1 screw. and when the vacuum is (sucked on) the plate tightens down then slides. am I missing a screw? is something obviously wrong before I tear it apart?
Thanks guys
-ECU
-ballast
-alt reg
-coil
-ign switch
Thanks guys
