Duster front end leans in at top
ohio
the tires lean in at the top. i have replaced front/rear shocks pitman arm outter tirerods lower ball joints upper control arms (tubular)by Mancinni
i have read that also(too much camber) this started out that when driving the car the front tires would scream like a belt was too tight. this was made worse or better when hitting a bump/expansion joint while driving. the front end shop said that there was a crack in the K-frame but i could not find the same issue later when i got it home. i kind of wonder if he had showed me the lower control arm bushing was shot.
