TT'74
I know you all have dakota/durangos, but you're mopar guys so I figured I post here too.
I'm talking to a local tubing bender about perhaps making a simple Twin Turbo kit that will replicate the one I'm making for my Duster. So the kit should also fit darts, valiants, demons, scamps and might also fit B or E bodies. I'm trying to make this an economical, minimum to no welding option for the Mopar crowd.
What will be included in the kit so far will be Up pipes, Down pipes, feed/drain lines and fittings, Cold side piping and custom carb hat. All of the tubing will be mandrel bent for now. I'm also going to try to find a local company to offer regular pressure bent pipe. This kit should be a direct bolt in, if the buy has magnum manifolds and grand national turbos. It would also work for other T3 turbos with minimal modifications.
This is what I'm modeling the kit after (production unit will have a different carb hat):
Hat for the kit will be more like:
http://www.ebay.com/itm/Blow-Throug...pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
