Dynomax mufflers
johnnycuda
JohnnyCuda's 68
I noticed alot of you guys like the ultra flows.
since putting in the stock tank i have to redo the tail pipes.
i was thinking about changing out the muffs also i noticed mine have center inlet and offset exit.
wondering if mine were put on backwards?
Most have offset inlet and center exit and i'm already pretty close to the drive shaft as it is .
Any suggestions without having to redo my x pipe too.
Or is it just trial and error and hope for the best?
thanks Johnny!
Uploaded with ImageShack.us
I believe you can get them offset on both ends, one end or just straight through. Mine are offset on both ends but I remember seeing the other types when I was shopping.
I put Ultraflos on mine after researching back pressures. They are one of the lowest back pressure street muffler out there.
Most mufflers have flow arrows stamped in the housing.
Your tailpipes should exit outside the shocks, and maybe need swapped from side to side?
Yeah i tried to switch sides now that the tank is back in.
But the bends are wrong and will not fit i need to redo them.
the proper mopar mufflers are usually offset in and center out. guess it makes it easier to line up tail pipes.
I dont know what to do, originally i had a 3 inch exhaust to the tips.
That was with the tail pipes run the wrong way where the tank went.
Since putting the tank in i have to redo the tail pipes.
but there is not alot of room and dont want any issues.
Can i buy pre bent tail pipes? if so which mufflers do i buy exit center or exit offset?
