I bought all all my lines, fittings, filter, pump, and regulator to be E85 compatible. The carb will be soon. The only thing that I was worried about was the new 20 gallon aluminum fuel cell since it is bare. I didn't want my plastic cell anymore since it wasn't quite as nice looking as an aluminum cell. Some guys have had no corrosion issues with the aluminum cells and some have. I'm not taking the chance so I found a local place that is going to anodize the fuel cell inside and out so the E85 won't corrode it. I had to call around quite a bit to find a place that would do that. Most said it couldn't be done, but it can apparently. Something to consider. I would try to get anything that's bare aluminum anodized.
