early a body swap with factory k frame
TheGreatGazoo
Member
New York
Hi last summer I did a gen 3 hemi in a 69 b body.
This winter I am thinking of doing a early a body. a 66 valiant my question is has anyone have any success using a factory k frame. I have been searching around and only came up with people replacing the k frame with like Alter k.
all help would be greatly appreciated
I stuffed a 340 into a 65 Valiant using 273 engine brackets on the slanty K.
I had to slightly modify the one engine bracket to take advantage of the slightly different block ears on the 340. I think it was the passenger side. The mod was to weld on a triangular piece of metal and then drill the hole in the appropriate place; easy-peasy.
