Early A shifter hump question...
metallidart
member me?
Legendary Member
East Palestine, Ohio
I saw somewhere that the 63-65, 66, and 67-up floor shifter humps are different. I have a 66 Valiant that I'm putting the shifter on the floor, and I was wondering how close the 67-and up humps are to the 66? Completely different, or could I modifiy and make it work? Or should I just get the $99 fiberglass one from brewers?
You could probably modify it, I used one from a 66 Cuda in my 66 Valiant, perfect fit. The 64-65 humps have a smaller hole for the shifter, hole is round, 66-up shared the same oval shaped hole. If you find an earlier one you will need to change the hole. The 66 manual floor hump is a 1-year only part!!
The '67 up humps aren't close at all. For the amount of work it would take to make one fit, you could make your own hump. Save yourself a lot of headaches and get the one from Brewer's.
They list the one in brewers as a 63-66, but it has the oval hole for the 66 and up according to to the pic. I think I'll do that. Thanks!
Correct for 66. PM sent
