Eddy RPM P&P Flow #,s wanted
pettybludart
Ontario,Canada
I have some Eddy RPM heads I,m gonna take in for some porting and polishing and thought I,d see what other members have gotten for flow numbers.Also prices.Thanks.
one more place to check on is
Modern Cylinder Heads.....Jeff usually has a winter special for cnc porting of any aluminum heads, I had a set of eddy rpm heads ported last year.
I am away from home working so i dont have the flow chart to post....but his price is the best i seen....you could give him a call and see if he does the special again this winter.. I remember i shipped my heads in dec last year..
http://www.moderncylinderhead.com/
Thanks for the links and info 70aarcuda,but shipping these is out of the question.I,m having a local do them for me and will also be flow tested.I,ll post #,s when there done.:toothy10:
Just got mine a couple of weeks ago from Nick Wilson at Compu-flow. This is a mild port (Stage 2) with exhaust porting. I also had him gasket match my Air Gap intake and mill the heads for my desired CR.
Superflow 1020 @ 28" water
Intake
.1 60.4
.2 120.5
.3 181.2
.4 230.9
.5 261.8
.6 269.2
.7 259.2
Exhaust
.1 50.6
.2 103.6
.3 144.2
.4 144.6
.5 188.6
.6 193.2
.7 194.9
Here are my Edelbrock heads that Ryan Johnson ported @ shadydell speedshop. This is his stage 2 port.
LIFT--IN/EX
.100"--63.0/NA
.200"--137.9/98.2
.300"--191.6/141.9
.400"--243.8/171.9
.450"--262.2/181.5
.500"--281.3/188.4
.550"--289.8/193.8
.600"--292.9/196.6
.650"--292.9/199.9
.700"--292.9/202.1
Heres the numbers for mine,mind you these were basically just cleaned-up nothing serious at all probably a stage one job at most places..
Intake:.lift 0.100-74.5
0.200-146.6
0.300-197.5
0.400-238.5
0.500-256.4
0.600-263.5
0.700-263.5
exhaust:lift0.100-65.6
0.200-116.7
0.300-148.3
0.400-181.9
0.500-193.4
0.600204.4
0.700-208.5
i plan of having more work done to them over the winter,probably a Ryan j. stage 2 job...
