if u want to do a little that will help, make sure there are no sharp edges under the valves, around the seats.--------smooth is better!Im gonna take your advice and thanks for giving it
I thought the heads were gonna be here yesterday but when I see them and get the chance Ill post some pictures with at least two valves removed just for the sake of saying I looked at leastif u want to do a little that will help, make sure there are no sharp edges under the valves, around the seats.--------smooth is better!
First Ive learned my lesson, I will NEVER deal with cast iron heads again cause they have the cost of these so low that its really a minimal cost above having the iron heads gone thru.
That lesson cost me roughly 400 dollarsx2
Words of wisdom
This is incorrect and misleading because Edelbrock doesn't do any clean up work on there heads but just a basic machining at the port windows.Lastly, these heads are definitely not ready to go out of the box, you can see where casting has already been cleaned up on the intake side, they did a shitty half assed job,
Thank-you for the kind words, Im gonna take better pictures and so you can see what i mean, maybe Indy cylinder head gave me a set of used heads or heads that someone has already done work too and if that was the case than Im not gonna be shocked.This is incorrect and misleading because Edelbrock doesn't do any clean up work on there heads but just a basic machining at the port windows.
Nothing more, nothing less.
It has always been said here on the forum that any head should be looked at by a machinist before installing and run.
But! Many, including myself, have run the Edelbrock head OOTB without any problems.
What your untrained eye sees may or may not be accurate in its conclusion. I hope your wrong for only one reason and that would be because of the hope Edelbrock is doing the right thing as they so state. "Ready to run OOTB."
While you have them at the machinists shop for there check up, perhaps some additional work will be done?
Good luck with your build.
I've went both ways on this. I've run one set out of OOTB and the other was blueprinted so to speak. Can't say there was much performance of longevity differences.
Can you tell me specifically what was done to the head to say it was blueprinted...is there something I should do or could do just as some precaution, maybe catch something that might have otherwise cause a problem?
I would most likely spent the money and have them checked out though. Nothing worse than ripping the top end off an engine after everything was put together.
Not trying to stir anything up and I appreciate your post but I called Edelbrock and guy was verk friendly and knowledgeable, he said they absolutely do go in there with a hand die grinder at the end and do clean up work on the last inch or so of the runners so that is prob. what Im seeing.This is incorrect and misleading because Edelbrock doesn't do any clean up work on there heads but just a basic machining at the port windows.
I've run Edelbrock heads right out of the box before without any problems but it is usually a good idea to take them apart and double check the guide clearance and then put them back together. If you have the correct tools it doesn't take too long to do that but the average guy in his garage will not have the tools to do the job. In that case you need to decide to put them on OOTB or take them to a shop.
Now something like Indy heads should never be run OOTB. Indy heads absolutely need to be taken apart by a good cylinder head guy and gone thru before running them. Edelbrock heads are usually pretty good, AFR heads are often better than Edelbrock and can be run OOTB, Trick Flow heads are usually ready to go OOTB, etc. If you are building engines on a daily basis you can tell which heads can be run and which ones can't be. But the engine builders I work with tend to pull everything apart before they go on the engine. Better safe than sorry and all of that. Engine builders hate to spend time on warranty work since it costs them double.
As for porting I don't think I'd bother. Especially if you don't really know what you are doing. You'll most likely cause more problems than you'll fix. The RPM heads will make good power OOTB. If you want more power then send the heads to someone like Porter Racing Heads. Or better yet, buy the heads from someone like Porter Racing Heads and have him do a stage I porting before the heads get sent to you. That way the heads are checked over, guide clearance is all double checked, valves are lapped in, the lip beneath the seat is smoothed out, etc.
Thanks for not taking it the wrong way, I dont want to step on anyones toes that takes the time to read, comment positively and help me to understand a subject.@1930 Glad you spoke with Edelbrock on the subject. And since the tech @ Edelbrock says they go there then we have two different ideas of what a "Clean up" is on a head. ;)
FWIW, Porter racing heads is worth every red cent you spend.
I called him back because I was anxious, again couldnt be any nicer or more professional ( I like to comment on the good AKA Summit and Edelbrock for instance ) ( as well as the bad AKA 440 source and Indy/aerohead )
He said that they did not look to have been touched by someone outside Edelbrock but still something didnt may not have looked quite kosher to him either so he has forwarded my pictures to his boss for review.
He did mention to me that if the conclusion was that there was an issue that they would have zero issue with sending me a second set of heads.
I pointed out to him the pronounced ridge at the edge of the intake runner that would definitely have to be addressed, sent him a picture with a small tool sitting on the ridge and he acknowledged seeing what I ws talking about.
He did comment that I may be just a little bit too picky ( not in those words ) and my rebuttal was that you may be right. I am a picky person and try to do the best I can do with everything I do and I foolishly expect everyone around me to do the same.
His e-mail address is mlevin@edelbrock.com and he mentioned to me that he would be happy to talk with anyone about the hand grinder clean-up process that they perform to all these cylinder heads.
If they think they need to be returned Ill most likely decline, its minimal, Im not sure how gasket matching works, if its the head side material thats removed or intake side, maybe both. Im assuming if the head is the least bit touched its gonna go away in nearly an instant. I only brought it up cause its there and I didnt expect it from an otherwise really nice looking head and so Im wondering what else I maybe wouldnt expect too see.I bought the first set of those heads from Mancini when Edelbrock First came out with them. Mine had that intake ridge i think you are talking about.me and my friend just used a dremal tool and removed that ridge.cleand up the heads and put them on my 440. so more or less those heads out of the box, my 3500 pound 65 Plymouth ran a bunch of 10.56 in the 1/4
What I meant by gasket, is gasket matching, it is easy and simple, just be careful with the dremel and you can do your heads, intake, exhaust.
Do not attemp porting, just go for the gasket matching.
