superdart360
I bought a new edelbrock thunderseries 650 carb. Everything works great until you stomp on it. if you stomp on it from an idle it hesitates, stumbles for about 1/2 second then it comes to life. The higher the rpm you are when you stomp the less severe the stumble.
Here is what I have done, I read the entire manual on the carb and followed every tunning setup guide to the T. I adjusted the mixture screws exactly how described. Didn't change anything. I thought it may have been timing at first so I adjusted and tested made no difference. Called a friend told me to try to cover the secondarys with my hand and crack open the throttle. This did reduce the the hesitation. So I changed the secondary butterfly to open as late as possible. This helped but didn't cure the issue so I don't think that this is the right way to go.
So the way I understand it at this point is if you cover the secondarys to reduce air flow and it improves the issue the motor is not getting enough fuel to go with the amount of air?
So I ordered 2 sets of jets for the secondarys to test this. The secondary jets from the factory are .98" I ordered 1.01 and 1.04 to test.
Please let me know if anyone has any thoughts on this. Am I going the right direction? Or am I way off? Any input would be great!
