draginmopars
picked up a set of used 6077 heads
replaced some valves, did a valve job, plus a little porting
building a 1970 spec 340 engine
cam is 268* at .484"
.040 over pistons are .035" above deck
using a 1008 fel pro gasket at .040" compressed
heads are .060" recessed chambers
was thinking of trying to get some quench
mill .030"
as is, comp will be 10.75
milled increases to 11.47
trans is 4 speed
What do you think ?
mill .030"
trans is 4 speed
What do you think ?
