Edelbrock Performer cam
mopar_nocar
Texas
I did some searching, but to no avail....anyone running the edelbrock #2177 cam?
If not, thoughts.
Mine:
Small duration cam, seems it would be real torquey.
sb
edit: fixed the part number
Good to cut up for fishing weights.
My dear uncle even complained about the lack of everything!
And he is one easy going relaxed dude. When he bitched, LMAO, I knew there was a problem. It was a gutless wonder.
Hummmm, well, he said Performer cam. So I figured that was the broom stick cam. The RPM cam has a good bit more duration. IMO, it's a shame they didn't give it more lift to take advantage of the heads better high flowing ports.
Oops, sorry about the number snafu. I did mean the cam. So, the consensus is that one would be better off just leaving the stock cam in there?
sb
Here is my story,take it for what you will. We built a fun car for my neighbor's girlfriend to drive. 80 Volare' stationwagon. 318,904, 8 3/4 with 3.55 gears. Stock bottom end and heads. The Edelbrock package #2177 cam, their valve springs, performer intake and 600 Edelbrock carb.Nothing special with the heads,clean up with springs and seals.Hand hone block with fresh rings and bearings.Cheap Summit headers, turbo mufflers and dual exhaust. The car in full street trim weighing in at close to 4000 lbs ran 15.40's all day long and sounded good.Nice idle rumble and at wide open throttle.We thought it worked good.
Slooow ramps and meager lift, not what you want in a streeter, but good for a lawnmower.
A streeter wants a modest duration with fast ramps and hi-lift.If you have to sacrifice RPM to get it may not be a big deal. As long as you have enough rpm left to hit 50/60 mph in first gear you are golden.
With the more typical 3.55s, 55 mph is doable at 5900rpm with an automatic and 27s. So a .550lift cam at about 220* is almost ideal. Of course the heads will have to support that.Tons of torque, adequate power, and just the right power band to be fun.
I wouldn't pull the stock cam out to install a 2177
Another thing to consider is that installing much more than the stock spec cam will likely make a torque hole just off idle, unless the compression is bumped up, to keep pace. The Edelbrock pkg with 63 cc heads does that, so as a package, it works.But if you are a gearhead, the modest power increase will soon wear off and you will be looking for more. Then typically if you jump to a 230* cam the compression needs to be brought up, or a hi-stall and gears band-aided on.
It's always best to to build the "final"iteration first, having brought the compression up to match, using a thin headgasket. Then if the cam is too big you can move down one or two sizes and install matching headgaskets to keep the DCr where it needs to be.
If you stick proper pistons in it from the get-go, you have a base from which to build on. A modest streeter with hi-comp pistons can make good use of iron heads. Back in 98 when I built my combo, good iron heads were not out there, so the Eddies were a no-brainer,but today we have several good iron choices.
