Slappy
I just got some edelbrock performer rpm heads 6077 anyone know anything about these heads? Are they reliable? Are they good heads? ect.
I don't want to steal this thread but I have a question.
I am in the beginning stages of a 408 build. I have contacted Campbell, AD Perf. and Hughes about the rotating assembly. I wanted to use flat top pistons with the RPM heads, but I was told that it wasn't a good idea to use flat top with the build and these heads because the CR would be around 11.5-1 and that was real close to the limit on these heads. They all advised staying with dish pistons. True/ False?
I had 11.9 to 1 compression in my 416 using mildly reworked Edelbrocks..no issues what so ever...
On pump gas...? Here we have v-power 99+ and we can't drive 11.9 on that, max realy MAX 11.0 cr whit 112 lsa and 300+ advs dur cam.
or are i miss understand the
?question?
Theres guys running in the NINES with them..nuff' said:-D:-D
I'm running a set of them that were ported, valves were changed to 2.05, changed to a heavy set of springs to run a solid roller...and i'm running in the 9's with them, so I would say they are good for the money.
ok, i don't take that risk and go for 11.0+, like you said thats how the parts are together...always fun to hear what you/people on fabo have to say about this things.
Thanks for all the replies and so great answers. I will say that I talked with a couple of different people and none of them said I can't they just recommended against it for the reason I stated. They did say it probably would not run real well on pump gas.
I have decided to use dish.
All of you give great info.
Thanks
