BillGrissom
Finished my EFI fuel system and thought I'd share my approach since I spent way too much time. May ease the path for others. Not asking any questions, but would appreciate useful comments for me and others.
My plan is to first supply a carb, then TBI, and eventually MPI, with minimal change to the fuel system. That way, if the TBI fails on the highway, I can switch back to the carb to get home. Of course, can't backup once I go MPI since a different manifold. I start with a carb because I have one I know works and don't want to wipe my new cam when I firt start the engine, plus want to document the mileage difference between the 3 fuel systems.
Details to the photos:
Sender is 3/8" supply and 1/4" return (ebay ~$45 new).
Ran 3/8" steel line and "fuel injection" type rubber hose. Used the factory 5/16" line for return. I tried to minimize rubber hose and used barbed fittings w/ "fuel injection" type clamps where I had to use it. I slightly flared bare steel line to better secure the hose.
I used SAE flare fittings on the steel tube. Compression fittings are not recommended since theoretically the tube could pull out of the nut and cause a massive leak. Two flares leaked slightly, but I fixed by inserting a green O-ring in them. A thin copper "soft seat" or "Voishon washer" is the suggested fix, but didn't have any.
The fuel pump is a Walbro 190 LPH (GSL391?). Several fittings are available for the 10mm x 1 threaded ends. I used the 3/8" barbed hose fittings, which come in the $10 installation kit. I drilled and tapped 2 holes in the passenger side inner fender to mount. The pre-filter is a generic 3/8" type. I covered the hose w/ silicone-fiberglass heat shield where it runs past the exhaust header.
Following the pump is a Microguard 33737 filter/reg ($20 at O'Reilly's). It is used on Corvettes and relieves at 58 psi. Inlet fitting is NAPA 730-4927 (3/8"), return fitting is NAPA 730-4926 (5/16"). For the outlet, I bent a 3/8" tube from an early Magnum SB fuel supply (regulator rail).
At the pressure gage, I switched to 5/16" fitted hose from a later Magnum SB (return-less rail). All three of my fueling systems will attach to this hose via a male 5/16" quick-connect tube ("Bundy" fitting). For the carb, I used a piece of tube from the later Magnum. At the carb, I made a tube w/ dbl-flare to SAE flare.
For the carb, I need to run ~10 psi at the fuel pump outlet. I have an old Pro-Fuel type pressure-reducing regulator to supply the carb at an even lower pressure (adjustable). I first tried a home-made 10 psi bypass reg made by adding a hose barb to a Norgen 30 psi air relief valve (shown) and swapping in a weaker spring. It tested 10 psi w/ air but ran 22 psi on the fuel pump. It held a perfect 10 psi w/ pump off. When replaced with just a hose barb, the system ran 9 psi. Thus, most of the extra drop was due to the return plumbing, most likely the 1/4" restriction at the sender. Only 3 psi was "proportional offset" in the reg. This determined I don't need the bypass reg, and can just use the return drop for the carb. However, when I switch to TBI might be a problem since the Holley Projection specs <4 psi drop in the return line.
Pre-emptive answers
1. The fuel pump is pretty quiet. Can barely hear it in the cabin with the engine off.
2. I know people recommend installing the fuel pump close to the tank, but didn't see a good place, wanted a clean protected place and where I can access it on the highway if it fails, and I have run one for decades on the inner fender in my Newport with a 5/16" supply line and no problems.
Finally, since someone recently asked "what EFI pumps are there?", I show 2 other external types I know of besides the Walbro. First is the "1990's Ford Truck" type I run on my Newport. Similar ones are sold under many brands (MSI, Holley, ...). I have only seen outlet fittings for 5/16" hose. The thread looks like 1/4-20 but don't quote me. The inlets fittings I show are 1/2" and larger, but I have a 5/16" inlet on my Newport. The other pump is a Bosch used on Mercedes, Audi, etc. It has a 12mm - 1mm threaded outlet. The installed fitting is a banjo-type w/ check valve. The inlet is ~1/2". I bought it cheap but will re-sell since too hard to adapt.
Pre-emptive answers
