MoparManiac2000
New Member
Lurker here that after many years finally made a profile. You all are of course A body focused but are the best Mopar/Car forum community around! I asked this in For trucks only but I am gathering opinions.
I have 77 D100 truck with an 318 2 barrel carb. I am dead set on an EFI setup. I understand (thanks to you guys) that it's not plug and play but will likely require a fuel system, re-wire and some engine modification at the least to be done correctly.
I am not particular to this truck and equally like the later rams that came with TBI and magnum engines (88-93).
Considering the time, money and parts commitment would you all just sell/trade for a later truck that came factory with this system if you wanted and EFI truck/car? Like I said, this is just in regards to setup, not that if you prefer the 70s trucks over the 80s/90s ones. I would likely use a Holley sniper or FiTech if I kept the 77.
