rmchrgr
Skate And Destroy
If you or anyone else is still befuddled/angered by computers and software in 2025 it must be difficult to navigate life in general let alone retrofit EFI systems. "Detesting" anything is purely emotional. You have a right to feel however you want about it but it's not relevant to whether it works or not.That's where people get me wrong with it. I spent YEARS on the line as an alignment tech. Why is that important? Because in dealerships, the alignment tech gets all the stuff no one wants or can figure out. Which means I got a ton of driveability. I learned a lot. I know way more about EFI than I let on. I know enoufh to know I don't like it and that's enough for me. Intimidated? Hardly. I detest it. Computer and cars should have never happened.
That said, alignments obviously have zero to do with fuel injection or any type of ECU managed systems (well maybe some BCMs) so the correlation about solving "drivability" issues is a bit thin. Being able to troubleshoot stuff others don't know enough about is a good general skill but I'm not sure it necessarily applies directly to jobs that require a fairly specific skill like sound wiring. Did doing aligments somehow give you insight into building transmissions or how to do body work and paint?
These retrofit systems are only as good as the people that install them. If someone skimps out on certain parts, ignores instructions or thinks good wiring is twisting two wires together and covering it with a roll of electrical tape then they probably shouldn't be messing with this type of thing to begin with.
Garbage in, garbage out as they say.
