Electric fan???
Heating / Cooling / AC
  1. Metal bee 68
    Metal bee 68 Well-Known Member
    88
    1
    Jul 4, 2010
    kansas
    Local Time:
    3:54 PM
    I've got a 72 swinger, 225 /6. Making it a daily driver. Is an electric radiator fan a good idea? And any recommendations are appreciated. Thanks!
  2. pentastarpro
    pentastarpro speed trials
    62
    31
    Oct 25, 2009
    Apple Valley,CA
    Local Time:
    1:54 PM
    Going electric has never solved a temp problem for me.
    Proper pulley ration & correct fan has always been sufficient.
    Good luck.
    • Like Like x 2
    • Agree Agree x 2
    • kursplat
      kursplat FABO Gold Member FABO Gold Member
      3,594
      2462
      Aug 24, 2010
      so cal
      Local Time:
      1:54 PM
      are you having an actual problem or just curious? no reason the stock setup, in good shape, shouldn't cool a stock motor
      • Agree Agree x 1
      • Metal bee 68
        88
        1
        Jul 4, 2010
        kansas
        Local Time:
        3:54 PM
        I'm putting it back together. I don't have a fan shroud and was curious if there are other better options.
      • Mattax
        Mattax Just the facts, ma'am FABO Gold Member
        11,175
        7070
        Feb 7, 2013
        Phila. Pa
        Local Time:
        4:54 PM
        Shop manual will show if the factory thought it needed one.
        They help mostly when the car is not moving - which these days is when we're stuck in traffic. :(
        A shroud for '72 shouldn't be that difficult to find and mount. It's the pre-70 shrouds that are somewhat rare (but now reproduced).
        To your original question.
        Electrics are not usually as good as mechanical in terms of airflow.
        More important IMO, adding an electric load to these cars, especially something like a fan that will be running at idle, really requires some modifications to the original wiring strategy.
        • Like Like x 1
        • Agree Agree x 1
        • kursplat
          3,594
          2462
          Aug 24, 2010
          so cal
          Local Time:
          1:54 PM
          22" or 19" radiator? do a want ad or hit some wrecking yards. /6 fan shrouds shouldn't be too hard to find. that car can make a great daily driver, just need to work out the kinks :thumbsup:
          • Like Like x 1
          • Mike69cuda
            Mike69cuda 64 is the new 17 FABO Gold Member
            1,860
            1385
            Jan 2, 2018
            Overland Park Kansas
            Local Time:
            3:54 PM
            I was just out looking for a 22 fan shroud. Bought one off a dodge truck at pick & pull awhile back and it worked fine. Went looking for another one. Never imagined there was such a dizzying array of fan shrouds. Must have got lucky the first time. Couldn’t find anything close. All the old stuff is long gone around here.
            Wound up making one out of a couple of Ford Explorer top halves. Too cheap to spend $200 for a repop.
            • Like Like x 1
            • kursplat
              3,594
              2462
              Aug 24, 2010
              so cal
              Local Time:
              1:54 PM
              check out this thread too. i know the thread is old but Dan say's they're still a good source for parts
              Old Car Parts Northwest
              1120 SW 16th St. #7
              Renton, WA 98057
              Phone: 425-572-0764
              Email: ray@ocpnw.com
              • Like Like x 1
              • devilchicken
                devilchicken FABO Gold Member FABO Gold Member
                207
                109
                Sep 14, 2014
                central Califorina
                Local Time:
                1:54 PM
                I have electric fans cooling my big block and they work fine for me but I had to do a whole slew of other upgrades as well. I have a universal relay/power block to power the fans and to not tax the original wiring, a Dakota digital fan controller so I can dial in when the fans turn on and off. Lastly I had to upgrade the alternator to a 100 amp unit and the main charging wire from the alternator from 12ga to 8ga to handle the power requirements. This the direction I went with for cooling a big block in a A body and if you are just keeping things as a daily driver I would stay with the factory pieces but if you do decide to install a electric fan look at it from the point of view of what other pieces are required to complement the fan (wiring, thermostat, upgraded alternator, etc)
                • Like Like x 1
                • harrisonm
                  harrisonm Well-Known Member
                  2,855
                  2790
                  Jan 16, 2005
                  Topeka, KS
                  Local Time:
                  9:54 PM
                  I had some problems years ago with my 69 Barracuda with a moderately modified 340. I fiddled around with several electric fan combos with no relief. I finally went with a stock fan shroud and a 6 blade belt driven metal fan. Problem pretty much solved. On a HOT day with the AC running, it does get a bit warm, but it has never boiled over.
                  • Like Like x 1
                  • RustyRatRod
                    RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
                    65,726
                    39033
                    Jun 7, 2010
                    Georgia
                    Local Time:
                    4:54 PM
                    No.
                    • Like Like x 1
                    • j par
                      j par Well-hung Member
                      25,366
                      13448
                      Jul 2, 2014
                      Portland Oregon
                      Local Time:
                      1:54 PM
                      I have an electric fan and have use them for a long time. I recommend them in all of my customers hot rods as well...
                      I do not like the "whirling blade of death" as I call it..
                      First you have to run it as a puller which is much more efficient. Also a simple temperature sensor hooked up to a relay. Most parts store alternators are a little over 60 amps which is plenty. Those hundred amp alternators don't really do anything until they're up to a RPM... as in there not helping at idle in traffic any more than a parts store one... This is where a good battery comes in to kind of take up the slack for those moments when the alternator can't put out...
                      I'm a fan of electric fans...:D:D...
                      • Like Like x 1
                      • goldduster318
                        goldduster318 Overzealous Car Modifier
                        1,645
                        194
                        Aug 25, 2007
                        Lake Orion, MI
                        Local Time:
                        4:54 PM
                        I would say they both can work fine. The most important thing here is your radiator - so basically your radiator should be able to keep the car cool with no fan at all at a cruising speed, and only really need it at idle on a warm-ish day.
                        Also, a lot of the aftermarket electric fans are just crap to begin with, so I don't doubt a lot of you had issues. You want to use one adapted from an OEM application of some sort. There are a lot of good ones for different sized radiators, Ford Contour 2.5 V6 for a 26" rad or a Taurus 3.8L fan for a smaller one are usually good places to start. I have heard of HHR fans and some other ones that are decent as well.
                        In my case i have a 340, champion 26" 3-row, and the Ford Contour fans - and I only need the low speed. I'm also not losing 25 hp by running a fixed fan.
                        You will need a better alternator to run such a big fan, which would mean no factory Chrysler roundbacks or square-backs because they don't put out much at idle. I have a delco 12SI on my engine and it puts out about 55A at idle and it's only a 78A version.
                        • Like Like x 1
                        • BillGrissom
                          BillGrissom Well-Known Member
                          7,394
                          411
                          May 10, 2009
                          Sacramento
                          Local Time:
                          1:54 PM
                          To match the airflow of an engine-driven fan, you need a powerful electric fan. The 2-speed Taurus fan move a lot of air and is popular with hot-rodders. If you can fit an engine fan & shroud, do so. My 1985 M-B diesel has both an engine-driven fan and pusher electric fan. The electric fan turns on from refrigerant temperature, so its main purpose is to cool the evaporator when idling. Even that isn't sufficient, since the AC gets noticeably warmer when sitting at a long stoplight. That is also true for my 2002 Chrysler minivan, and yes I verified that both fans turn on. Once you start moving 30 mph, the AC gets noticeably cooler.
                          • Like Like x 2
                          • goldduster318
                            1,645
                            194
                            Aug 25, 2007
                            Lake Orion, MI
                            Local Time:
                            4:54 PM
                            Yeah, it's interesting when my uncle's 2008 Silverado 2500 with 9600 GVWR has electric fans, I think they've come a long way, but they do it for fuel economy and also as you mentioned to make the A/C work better.
                            • Like Like x 1
                            • DrCharles
                              DrCharles Well-Known Member
                              1,007
                              772
                              Jun 7, 2012
                              West Plains, Mo.
                              Local Time:
                              3:54 PM
                              The Contour dual fans move a lot of air, and fit nicely on a 26" radiator. Keeps my 451 cool in mid-90's humid Missouri summers :)
                              I believe you meant, "cool the condenser" :poke:
                              Sounds like you don't have enough condenser if both fans are working and the A/C warms up. Or did you do a conversion to R-134a on your MB diesel?
                              I used to own several (220D, 240D, 300SD) and on the 60 hp 220D I'd turn off the a/c when I needed every hp sometimes :D
                            • AJ/FormS
                              AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
                              19,416
                              7250
                              Jan 19, 2014
                              South-Central Manitoba,Canada, 900ftelevation
                              Local Time:
                              3:54 PM
                              My slanty has no shroud either, and just a 4-blade fan. It's been that way since I got it in 1994.
                              • Like Like x 1
                              • BillGrissom
                                7,394
                                411
                                May 10, 2009
                                Sacramento
                                Local Time:
                                1:54 PM
                                Correct, I meant the "condenser". Like most older cars, our 1985 M-B has a 1-tube copper condenser. The parallel-flow aluminum condensers in modern cars give 30% better cooling, so some owners retrofit one. Some also change from the Harrison R4 compressor (used in many Chevy's) to a modern Sanden 7-piston. I did until the aftermarket bracket cracked, but didn't notice the Sanden worked any better. Our 2002 T&C has a parallel tube but still the AC doesn't work well when idling at a long stoplight. A disadvantage of parallel condensers is that you can't flush out debris like older ones, though most people today just install a new condenser. Many owners think M-B under-designed the AC for the U.S., especially CA Central Valley where I live (110 F days plus evil sun), but the heater is built for frigid German winters, having a monster 3-tube Behr heater core as found in semi-trucks and climate system which disables the cabin fan until the coolant is hot so no risk blowing cold air on rich owners (Germans fear 'une draft' will sicken them).
                                • Like Like x 1
