I will keep that in mind with the failure issues. May use what I have and an old column to play with, and look for a more permanent fixture. The Hemi Denny setup isn't gonna work for me, I don't think its compatible with the Alterkation front end. Any EPS can be mounted, the trick will be how to trick the module into seeing a speed signal. I don't have enough I.T. background to make a speed generator for the module. I don't think the demand is quite there yet for EPS on older cars. Ten years ago, LED lighting was ridiculous and pricey, now its on ever parts shelf out there. Even now, its hard to find a suspension kit for a pre 66 a-body, that someone doesn't want to burn you on, cause its not a common build. Look at any after market company out there, you'll see 67 and up a-body, call them about a pre 66 and the price for anything will jump 10% or more. LOL. If only I liked Shivy or Foid. lol
