snailgarden
I’m facing an issue where my car (1968 Plymouth Valiant 100) is dying when the windshield wipers and blinkers are on while the car is in D with the brake pushed in. My car completely died while waiting to turn left at a light.
It wouldn’t start back up at all, wouldn’t even make a clicking noise. But it will start up completely fine in neutral. It’s just when I shift to D it’ll die again. It’s now done this two times (second time was just me in my driveway trying to recreate the initial issue).
I have replaced the ignition switch thinking it was that… before this, I replaced the battery, the alternator, and voltage regulator as well. It also has a new distributor, new spark plugs and wires. New ignition coil as well.
Could this be an issue with the neutral safety switch? Grounding issue? Or what? Any help would be greatly appreciated.
