Omar Flores
Mexican 76 Valiant Duster 225
Hi everybody. This is my first post here, hope doing it well.
I just picked up a 76 Valiant Duster (Mexico) slant six. Originally three speed on column but at some point was converted to floor shifting.
I decided to start on the wiring which was a mess, I´m trying to put something simple and reliable that allows me to track any failure at any situation. Ign and lights are the only I'm interested in.
Car has points ignition, I doubt the alternator and Vr are the original ones and I'm also using a universal ign switch.
So far looks like this:
Battery: + to Stater and Bat terminal in the ign switch.
Alternator: to Starter (junction point??) and I terminal on the VR
VR: I and S terminals wired together and to the ballast driver side
Ballast: driver side VR (I and S) and ign in the switch the other side to the + on the coil
Coil: + from ballast - from distributor
Starter solenoid: Bat - Battery. Sol - Start Ing switch, G grounded (no NSS), I to Ign switch
Ign switch: Batt - battery, Ign - I in the solenoid, Start - Sol terminal in the solenoid.
The car fired up, just wanna make sure this arrange is ok and safe. Suggestions are welcome. Next steps relay and fuses where are necessary?
Sorry for such long post, I hope this is descriptive enough.
Thanks for your feedback. Saludos
