Just Send It
There goes the neighborhood!
After watching that guy eat the dashboard of that Falcon earlier this year, I reinstalled my Parking Brake. Better than nothing.
I’ll never drive a car with 50 old lines or hoses. Those are consumable items that should be replaced every 10 years if not sooner.So when your master cylinder fails or you blow as brake hose, is your plan to just jam it in park while you're blasting down the road?
Asking for a friend that had a brake hose blow out a few years ago and a steel brake line rust through earlier this year.
10 years is a little aggressive for most of the US, but if you're in New York, you're damn straight; replace those damn brake lines!I’ll never drive a car with 50 old lines or hoses. Those are consumable items that should be replaced every 10 years if not sooner.
When I was first driving these cars, they were only 10 years old. I lived in Virginia, and yes, I had to replace most everything because of the Winter salt.10 years is a little aggressive for most of the US, but if you're in New York, you're damn straight; replace those damn brake lines!
Neons have one spot above the rear axle area that likes to rust out. I'm getting ready to replace everything on my Dakota. Seems like the armor on any steel line holds salt against it, too.
Around here, it does not snow. Cars don't rust out like yours do. There are no safety inspections. We do have emission testing for cars built from 1976 toI've had a few customers come in thru the decades, wit a "VI" ticket for a full inspection, crying the blues cuz they had a lite out, or waaay much neg camber rear, - knew it, then the officer stepped on the brake, and pulled the emergency, it's all part of the check they do if you give them "attitude" .
Twas a Comet, if memory serves, but yeah, no clicks for OPAfter watching that guy eat the dashboard of that Falcon earlier this year, I reinstalled my Parking Brake. Better than nothing.
Just to answer the first question.. Yes.Can I assemble without the e-brake shoe arm and rear drum struts?
It becomes "hostile" when some just don't answer the question that you asked and have to expound on it.I'm not concerned about the legality, I've never once had LE inspect a parking brake.
I am concerned about the functionality of the hydraulic rear drum brake system with the parking brake components deleted.
When did this place become so effing hostile anyway?
Anybody who would consider anything that has been said in this thread “hostile” must be awfully, awfully, sensitive.
There, there lol
Please post pictures and updates afterwards.The piston on my Dakota caliper keeps seizing causing the brakes to drag on that side. Since we're on the subject, can I just omit it?
.........This guy used a brick back in the 70's. Drag only car.I used a length of 2X3 doubled at one end for a chock. I could lay it on the ground from the driver seat and let the car roll to it.
After running without a while with a 4spd, I'd recommend a parking brake.
But, when I didn't have my parking brake functioning on my Barracuda, I used a length of 2X3 doubled at one end for a chock. I could lay it on the ground from the driver seat and let the car roll to it.
Then too there's these.........
Keep in mind too, you have no self adjuster feature now, so you will need to readjust accordingly from time to time. It's clean at least! lol
