Emissions Checks ie SMOG Check
Ridge
Riverside , Ca
I live in Southern California and we have to do emissions test
every two years to be able to register our cars. 1975 and earlier are
not required to do this. Whats the rules in your state.
In Louisiana the only emissions checks are if you live in an ozone non-attainment area, such as the Baton Rouge area. Older cars are exempt, but I'm not sure what the cutoff is. Fortunately I don't live in an area that requires emission testing for my Demon. In fact, if the car is 40 years old you don't have to even have a "brake tag".
here in colorado springs, it used to be every year, then it went to every other year, and within five years, it has disappeared all together.my old canadian built 76 chrysler cordoba did not come equipped with a cat converter or any smog BS so it was exempt from emissions here in CO. glad to see it go. we used to put our single exhaust pipe and two barrel carb and intake back on when inspections were getting close.unless it was a 440 lol
Where I live in Virginia - What emissions check? Now over in Northern VA and maybe the Tidewater area they have an emissions check. Had a 77 Aspen and the inspector looked to see if it had a cat.
Used to be a smog tech.(early 90s).Back then,you did a 4 gas test.All the paperwork was done by the smog tech.I don't miss the mid 70s to mid 80s vacuum line headaches.
Nevada just changed the law last Oct....car older then 25 yrs can be registered as classic vehicles...no smog test but you are allowed only 5000 miles a year.....but you still pay the 6 dollars the dmv gets from the smog test...
and no one checks the mileage on the car......you just fill out the form...
When I was in Norfolk from 99-03 they made me do a safety check. Forget if it was every year or every two years though.
California "style" emissions in Maricopa County, AZ. You have to get an emissions test for anything 1966 or newer:(
That's supposed to be changing for the better soon.
Here in Texas,3 cities and surround counties get emission check.
Houston,Dallas,El Paso and Austin.
1987-1995 get tail pipe testing and 1996 or new get OBDll test.
Diesels are exempt receive safety inspection.
1986 or older are exempt receive safety inspection.
All other cities and counties receive safety inspection.
Martin
Our Inspections are every year.
In Austin,Our safety inspection are 14.50,our emission inspection are 28.75....
Houston and Dallas emission is 39 something....
You sure it's not 68 and newer? Only CA cars had emissions in '66. Federally, it was 68 and newer
1966 been that way since they started the program.
EXEMPTIONS
A vehicle is exempt from emissions testing when:
It is a 1966 model or older.
It is either a new vehicle, or on its first or second registration.
It is a hybrid-electric vehicle less than five years old.
It is a motorcycle which has been registered in Tuscan city area.
It is a vehicle which a dealer is transferring to another.
It is a golf cart or similar small electrically operated carts.
It is an alternative fuel vehicle.
It is a vehicle which is registered out of state of Arizona.
It is outside the areas which require a vehicle emission check. In such case you can apply for an exemption under Code 52 of the Car Care programme.
On paper,Ab.No tdsting in Cali till 83/84.idle /2500 standing.About 2003/2004 (Im240) rolling dyno started.As of right now,nothing under 75 gets inspected.
I even have to take our '03 Ram Cummins in for emissions every stinkin' year:( Always passes with flying colors, all they want is mo' money...
Ca I believe is 76 and earlier and before that it was every year of present it was the same for the older meaning if it was 2006 76 smog legal, 2005 75 legal and so on, but they stopped it at 76
In the clinical sense,on the money, 73.Arnold called the wnistle.I have seen a couplei of 76 with exceptions .
in the county of fairfax, fairfax city, stafford county, city of falls church and arlington county, manassas , mannassas park and the rest of prince william county only, they have a 25year rolling and its required every 2 years... they also have a roadside sensing devise( for people going into those counties from out of town) that if you get nailed with a 1 month period they send you a letter to have it tested if you pass its free and if you fail you pay for the test and have to have it repaired.... they do a air sample of the shannadoah valley to see if they needed to add more counties. they wer suppose to add spotsylvania county and fredericksburg but the air sample was lower than the previous sample so they didnt need to add it.
also in the state of virginia if you have a car that smoke bad enough that it impairs yours and others driving you could get a ticket... no one ever does tho...lol
EXEMPTIONS
What you just said there is that 66 is exempt
But even 67 doesn't have smog Federally, only CA cars
You guys need to get on those people's asses and correct that
When I bought my 1965 Newport in CA in 1991, you had to get an emissions inspection whenever a car was sold, at that least vintage in that county. The report showed very low emissions, indeed it would have passed the limits for my 1982 Aries. They didn't test NOx then, and emissions controls then messed up HC and CO in trying to control NOx. The later 3-way catalysts fixed that and are much superior.
I recently bought a 1964 Valiant in CA and didn't need an emissions test. I don't know if the laws changed, or 60's cars are so old now they get a free pass. I recall reading that studies showed classic cars are generally well maintained, infrequently driven, and aren't a significant air quality issue. I suspect that an 80's car with failing engine control components would be much worse, and nobody can maintain those vacuum clap-trap setups. Of course, when people put thumper cams in classic cars, they can gas everybody within 50 ft of the tail-pipe.
When I lived in FL in the 1970's, you had to pass state safety inspections. I spent a lot of time and money trying to pass the brake test with my 1969 Dart. The brakes had just been rebuilt and were fine, but the machine showed more braking force on the left. That was a common problem, and usually due to just the driver's weight. Later studies showed that most accidents were caused by idiot drivers, not poorly maintained vehicles, so FL dropped those very unpopular tests.
I live near Jackson CA. Same, like 1976 and older = no smog check. The newer stuff gets the sniffer when you buy it and never again as long as you own.
Lived in San Diego for years. I think they put them on the roller dyno and sniffer every two years with like 76 and older exempt. I had a 76 monte carlo that I kind of remember not having to smog.
Funny thing is, there are millions of poorly tuned vehicles driving from mexico every year that are completely fouling up the atmosphere in our country. I saw it constantly in so-cal.
Dont even get me started on the un-insured motorists coming out of that country.
California has cats in the mufflers of the lawnmowers and small engines, with extra emissions requirements on them.
Mine somehow fell off my diesel generator so I put on the exhaust pipe an after-burner that runs off tar to clean up the exhaust gasses.
Thought AZ has a collectors insurace exemption, if the car has collectors insurance no smog necessary? County I live in Washington has no emissions test.....
Where the hell is Jackson in Cali?(2counties still exempt,in cali!)
