Captainkirk
Old School Mopar Warrior
Hey, folks, building my '72 340 Duster and I have the option of using 2 differentials. First one is the one that came with this car, a '72 340 Duster with factory A-833 4 speed. Not sure of the gear ratio but definitely less than 3.91. It's an 8-3/4 diff.
Option 2 is a 3.91, also an 8-3/4. This one came from my first car which came from the factory with a 340 3 speed manual. The difference in drive shaft diameters is pronounced with the 4 speed shaft being much larger (beefier) than the 3 speed unit. Visually the rear axles look the same, but the 3.91 has around 42k miles and the other one has over 100k on it. Is linking up the 3.91 gonna limit my top end much? This is planned to be a fun street terror car, not a daily driver or anything, so 100mph runs on public roads could get expensive, if you get my drift. Not planning on racing, maybe a one-time run just to see ET. Maybe a local car show now and again. Which ***-end would you recommend, and why? Decision time is right around the corner so need to get my ducks in a row for cam selection, etc.
