Showoff. lol
What is the cast lifter?...
The heads either have 1.88 intake valves or 2.02s... if they're 1.88 you can have a machine shop put in 202 valves...
That Carter 625 is a good carburetor and that performer will do just fine with the power level you have...and I should have cheap Summit headers and you should be good to go... Get a cam that matches your rear end gearing and your stall converter. Put Springs in your heads to match the cam....
ask a lot more questions about different stuff and make up more threads to learn more before you spend any money...
Showoff. lol
What's a rocket arm..?..
I was a little tipsy when I wrote that. I meant cast Rocket arm... I’m going to to start a new thread, because I’m obviously not ready and need advice with the engine setup. I thought I’d done plenty of research. Lol. I appreciate all the advice!
Mancini Racing - A Engine Adjustable Rocker Arm Set
Just keeping you honest LOL..Rocker. I put a link to it in the post where I misspelled Rocker.
I think I've seen hose cars. Still drooling!some might say that....I consider it MOTIVATION. If goofy ol' HemiDenny can do it...wonder what a smart MFer like (insert your name here) can do.
Here is a little more....motivation.
