oregonhd
big daddy John
So I have a new 440 I just put in my dart, I havent fired it up yet, filled the radiator and the passenger side rear block freeze started leaking ( good thing I used water) so I poped that out and changed it, so now I refilled it, not leaks, then front freeze plug on the same side started leaking, they are cooper, will they expand when I start it up? or do I need to change that one? and that one will be a little more diffulcult. never had this happen before?
