Engine Noise Update and Video
I did change the valve springs and put in standard locks instead of the -.050" locks that were in there. Ryan at Shady Dell picked out the springs/locks/retainers and told me what install height to set them at (1.85"). I changed the cam while the engine was being built (after Ryan set up the heads) and the springs were marginal for that higher lift custom ground cam I ended up with. Doubt that had any effect on noise but that is another thing that is different from the last time.
Glad you figured out the problem..and kudos to Ryan j.,was thinking about sending my Edelbrocks to him for some of his magic work,now get that badboy cuda' to the track and show em' what a smallblock stroker can do..:-D
