nm9stheham
Roger... I had not looked at the price so I can understand. The B&M ones like you linked above are designed along the same lines so may well be about the same performance. They have 1/2" NPT inlets and outlets, which are a bit smaller, but at least are as large as the line in and out of the engine so may be just fine.
You should check out Earl's too. Those look to be more like the Setrab's and have larger inlet-outlet fittings than the B&M's. Wide - Holley Performance Products
