fratzog lover
Rotella is NOT what it used to be.
when you dont sell a product you usually dont promote it . in the real world shell rotella has served me very well for many thousands of hours of use in all my engines and my mopars are solid flat tappet cams with fair spring pressures but i do put a few ounces of lucas breakin oil.this is just my experience and i do get a good deal on this oil plus i can write it off also i'm not sayin its the best but your cam wont go flat from using it like the article says either.
I do , have used synthetic for 30 years , my last 3 cars had over 250,000 miles on them and when I opened them up they looked new .do you guys think synthetic oil is worth the extra money?
I usually don't comment on the oil threads. My thoughts are even with a roller cam you need the zinc/phosphate components in the oil, it still provides a "protective barrier". You still have metal to metal contact between components. Rocker arms to shafts, push rods to rocker, lifters to lifter bore, piston to bore etc. With the increased spring pressures that go along with roller cams there's even more load concentrated on rocker arms , pushrods and side loading of the lifter in the bore. Of course this is my opinion and they are like everything else.
Almost all engines since the late '80's have been rollerized--they do just fine on regular plain Jane oil under most operating conditions. I get this question all the time when I build a roller cammed engine for someone--"What oil do you recommend?" My reply--"Whatever you want". If its not a marine or oval track or some other severe race condition--I don't care what it is as long as it can handle the heat and hold a given pressure. Are some oils better than others? Sure. Will a great oil save your engine if something is wrong? Doubtful--It will only extend the inevitable and not by much either. J.Rob
