I see 'stock bore and stroke'. Just make sure these are not original or original-like pistons. Those stick typically .018" ABOVE the block deck at TDC, and with a standard Felpro kit heads gasket, those pistons will end up being .030" or so from the bottom of the closed section of the head chambers; that is too close, and may well eventually end up with some piston-to-head contact, especially with engine wear, which allows the pistons to rock a bit more in the bores.
Compression would end up around 10:1 and DCR at 8 with that cam, depending on the exact pistons being used.
You could be right.
I have been running the KB107s, stock rods, and aluminum Eddies since the beginning, 1999.
I initially ran a zero-deck and .028Q for the first season, until I had enough of the 292/108 cam. At teardown that winter,(yr 2000) I found the gasket crawling into the valley, but there was no evidence of any piston to head contact.
I installed a 223/230/110 cam and swapped to the .039 FelPros for a Q of .039. That was my forever-combo; I thought.
Then about 3.5 years later that 223cam went flat.
I replaced it with one-size bigger a 230/237/110 cam and trimmed the decks another bit (cuz they were not square enough the first time)and ended up at .034Q;(I think that spec was plus/minus .0015). I also opened up the skirt gap to .003 at this time , cuz I had been having issues with hot-starting, running at 205*F.Then I re-installed the by-now well-used FelPros. And that is how it has remained ever since.
Up here those FelPros are close to $100 a pair delivered. Being a broke-azz-Dad of three teenage kids at the time,I decided to reuse them to see what would happen. I mean, I was freshening the engine every winter anyway.Those FelPros kept going and going and going.... they have been very good to me,lol. Worth every penny I paid for them,lol.
So bottom line is .034 has been working for me since about year 2004; and .028 worked for at least one summer on a fresh build. It
might have been good longer, with the better gaskets; but I wasna gonna use .028s again.
But you may be right.
I was more concerned about valve to piston contact. Running .579 exhaust lift into the KB factory eyebrows,with the 237exhaust duration cam, and hitting 7000 on a regular basis. I measured it but have forgotten the clearance. It would seem that the oem pockets are deep enough,lol.
IIRC all of these combos have run right around 185psi cylinder pressure, on the very same MacTools gauge.
Between the tight-enough-for-me quench and aluminum heads, she has always run on 87E10 without complaint.
That's my tight-Q story
