Engine Test Stand using K member?
1MeanA
Edmonton
I'm considering running my soon to be rebuilt 340 on a test stand before I install it in my Swinger which is under restoration. I've built a test stand for an air cooled engine which was a lot simpler and cheaper. I don't want to be working on the engine after its installed should any issues arise. Has anyone used the K member as part of the test stand. I'm wondering if its easier to bolt the k frame to a dolly than fabricate engine mounts. The only other issue is the expense of making a control panel. I would run at minimum starter relay switch, oil pressure and water temperature gauges. Perhaps there is something off the shelf I could use....haven't searched yet. I could use the rad I was going to install and temporarily adapt mufflers to the TTI manifold down pipes I'm planning on using. Ideas or suggestions appreciated. I have time for this build.
You would still have to fabricate mounts for the rear of the engine, or have the transmission attached and sitting on the ground.
Sounds like a sound idea, maybe a bit complicated in the engineering department, maybe just as easy to make a test stand if you have fabrication abilities?
Yeah I think I would mount the 4 speed gearbox and fab a support for it
I have see run stands (not based on a k-frame) use a bellhousing only. There is an earlier bellhousing (not A-833) that could possibly be a cheap score.
Frankly I see nothing wrong with your idea. You say "dolly" do you already have one? If not they are not that hard to build if you can cut/ weld basic metal, square tube, channel, etc. As others said you need a transmission installed or at least a flywheel/ bell and and something to anchor the rear of the engine.
Trans: Automatic would require a jumper tube for the cooler, a rear yoke, and ATF installed. You don't want to do so dry.
Without a trans, you need a bell/ flywheel/ starter and fabricate some bracket from the bell to anchor the rear, not difficult
Alternatively, you could use a flywheel and fab a plate to mount the starter. I have used just the engine plate off a scattershield. This is not "right" but I have "other starters" so if I break one it's no big deal
You really should at least fill the engine with coolant, even if no rad, so you'd need a jumper hose / tube of some sort to bring the lower outlet up even/ near the top outlet.
Controls? Really all you need is an oil pressure gauge, and maybe a temp gauge, but you can use "your hands" or a handheld infra red thermometer. They are nowadays cheap and easy
Electrically you need a simple ignition system, a battery and battery cables, and just basic jumpers to operate the starter.
What you have for a distributor will determine that. I often use an HEI module and coil "in a box."
This works with Mopar style breakerless distributors
I know it's "redneck" I've even test fired engines for a short time on an an engine stand, with makeshift support under the pan
This here is about the most redneck "engine run" I ever did..........
Made redneck adapter to mount AFB carb onto EFI magnum
img_1025-jpg.1715073120
Engine stand, engine plate, flywheel, starter mount........
A little "support"........
The emergency ignition box + a breakerless dist.............
You can make a run stand as complicated or as simple as you like.
Old friend of mine used to set the engine and trans on a couple of old tires in the shop floor and start it up.
Guy on ebay sells a bracket for big blocks to attach the starter without a bellhousing. Not sure if there is such a thing for a small block.
I've seen guys run VW engines on the floor. I guess you could run water through it with a garden hose but then you need to mount a coil, ECU, etc. Mine won't be quite that simple :)
I'm not worried about the starter as I can just use my bellhousing or mount the whole gearbox. I'm going to mount it all on the K member and roll it under the car when I'm done anyway.
If I were going to use a K frame I would use 66-72 B or E body as they are the same for small and big block if I remember right.
Cobbled this one together a few years back for my air cooled Porsche engine. It would have cost $800 to build if I had to buy every piece new....best pic I could find.
I saved the front frame ralls, transmission crossmember, core support and K frame from an early A I parted out. The K is the same for LA and slants with the only the motor mounts being different.
Too bad you‘re not closer, I’d give you mine. It’s in the way and I don’t need it any more.
A friend and his son helped me out with this US Cartool replica. I have to say, there was an oversight. I was hoping that this dolly could be something that could have the engine/trans/suspension installed by lowering the body over it but nope. The way the k-frame rests on the dolly is that there are two studs that go through the two front k-frame bolt locations. If the k-frame was supported in a way that did not use the bolt holes it could work.
There's no reason this dolly couldn't be used as a run stand.
I built mine to use a tranny. I didn't use a yoke but just put a bag over the ext housing to catch any ATF that might come out.
If I used my k frame I would have to be able to lift the engine, k frame and tranny as a unit and drop it on a cart to roll under the car for installation. I know some of the k frame carts are too high making it tough to slide under a car unless its on a 2 post lift. All I am accomplishing with this idea is the elimination of motor mount support fabrication which would take a bit of work. I've got enough to do.
Well look why not kill it all in one take? Build a K frame dolly and they are just not that hard, to do an install, and USE it pretty much as is to run the engine?
I threw one together and built it with short "fake" hitch receiver type construction, so it all comes apart Somewhere on here I had a thread about it. My situation is a bit different, because I have an (outdoor!!) 2 post, so the dolly in my case can be quite high, but smaller casters etc, can "fix" that.........
(Found the thread, it's "dead" "Thanks" to photophucket.............)
