T56MaxTorq
Have the heads off the turbo 318 and I'm wanting to dump off some compression other than using head gaskets. Right now I'm sitting 9.14:1 and I'm looking to drop below 9. I think I can achieve that by cleaning up the combustion chamber by removing sharp edges and blend everything. I need about 2cc gone to reach 8.94:1
The more the better.
318 magnum, stock bore/stroke
Stock pistons sitting .047 below deck
EQ heads - haven't measured chamber but advertised at 62cc. 1.92" intakes
.039 x 4.180 gasket
Live at 6000' so compression isn't a huge issue but I'm running e85, so I'm adding an extra 30%volume of fuel plus the extra fuel for 13lbs of boost at 12:1 AFR.
Main quest is to make the combo safer. Safer for premium fuel as well. Wanting to lower total boost to about 10psi. Which is 7psi at sea level. But attempt to keep the same power. Want to do a light chamber port, clean up the intake tract. Take a little out of the pushrod pinch and portmatch the intake. Unshroud the valves a little. The block is free game too. The crank and pistons are out. Any tips or areas to avoid or focus on? is removing 2cc possible or waste of time?
.039 x 4.180 gasket
