HI ALL,
i have a 68 383 4 speed dart gts all factory stock with mopar stage v heads and cam is p4452993
i took the car out a few weeks ago and noticed a miss while driving it .
checked it out on sunday and found #4 cylinder had the misfire
plugs and wire are good, compression around 135 A little less than all other cylinders that are 150
pulled valve cover and found intake rocker was loose ,removed rocker shaft and rockers
i can push lifter with push rod on intake side with no resistance. BAD LIFTER???
so i pulled lifter out thru the cylinder head and it wore and has a hole in bottom of lifter, basically its a junk lifter and cam shaft
my question is
what brand of cam and lifter set is the best out there???
the cam in the car is a mp p4452993
i would like to stay with the same cam specs
hydraulic lift 474"
overlap 60
duration280
centerline 110
my question is
hydraulic lift 474"
overlap 60
duration280
centerline 110
