Ever redrill axle's?,,,,,,,,can you?
sgd128
Here's what i would like to know..can i take a set of axle's and redrill them to fit small bolt pattern rims?? i have a b-body rear and would like to use the rims i have...
Its possible that you can redrill them to the smaller bolt circle. I think the problem your going to have is the axle register is a bigger dia. than the small bolt pattern wheels.
The wheels will not fit the axle. The center hole in the wheel is to small on small bolt circle wheels.
OK ..do you happen to know the axle register size (off the top of your head) for a BBP axle and SBP..
