I'm thinking of making an improved exhaust for my 1973 Duster
Good recipe: 2¼" headpipe into
this muffler. It's in Walker's QuietFlow SS premium OE line, all stainless steel (which is nice for durability), made for the '01 Jeep Cherokee 4.0 so it's easily got the flow capacity for a healthy 225 and it's tuned to keep an inline-6's exhaust from droning, has a 2¼" inlet and outlet. The inlet has a 2-bolt flange meant to bolt directly to the outlet of the Jeep's catalytic converter, and if you want to put the system together for E-Z muffler replacement you can put a mating flange on your headpipe, or there's plenty of length to the muffler's input pipe that the flange can just be sawed off in 5 seconds at the exhaust shop. It's got the 4¼" × 9¾" housing, muffler shell 20" long, so it'll be a bit of a tight fit in an A-body, but it will fit.
2" tailpipe with resonator (2¼" is not better, just louder). If I'm rich, I like a
Flowmaster HP2 stainless unit with 2" in and out. It's 18" long, which is a workable fit behind an A-body quarter panel. If I'm broke, I like a Walker №
17198 4" round can-type unit, 2" in and 2" out, with offset outlet next to a proper hanger bracket.
Speaking of that, whatever muffler you wind up with, make sure to use very soft hangers. The hook-and-O-ring type, for example. Today's popular "rod and rubber box" type transmits a lot of noise to the passenger compartment.
(Tailspout outlet 45° or greater downward.)
I was thinking of getting a mandrel bent piece of pipe and fitting it to the factory flange
Use a new flange at the top of your new headpipe—the old ones like to warp after half a century's thermal cycling.
to start a new exhaust pipe off at the correct size.
Can ream out the nominally-2" manifold outlet a bit, but don't get carried away.
All the Slant-6 cars were supposed to get 2¼" headpipes for '77:
At least some of them probably didn't; Chrysler were bleeding out and circling the drain at the time, quality control was already down the toilet, and every last fraction of a cent counted. Plus, who knows how many exhaust pipes have been replaced over the decades, with whatever came to hand/was on the shelf/etc.
